Coelacanth
- Jul 7, 2014
I must've searched nearly every EGR-related topic on this site to find out how to remove the EGR assembly and although I found lots of discussion, I couldn't find any with pictures, which makes the job a whole lot easier...so I'll document the procedure for anyone else who's considering this task.
The EGR solenoid with round black plastic cap isn't easy to get at until you remove the rest of the assembly. First, disconnect the one hose that plugs into the T fitting on the firewall. Then, there are 2 nuts holding on the EGR block to the right of the solenoid; a 10mm on the front, on the right side of the valve cover, and a 13mm behind it on the manifold. I got at the one in behind with a socket U-joint and an extension. Once it's loose, disconnect the connector at the back of the block, and the spark plug wire holder that's attached to the block.
Once the block and attached hoses are deflected, you can get at the single 13mm nut holding on the EGR solenoid with an open-ended wrench.
After you've removed the solenoid, disconnect the hose that runs to the round black & white check valve (to the left of the solenoid).
My question for those who've done this already, do you simply reattach a hose running from the check valve on the left to the now-open T fitting on the firewall, install the EGR block-off plate and call 'er done?
