EGR route?
Regallager(CND)
Just wanted to ask if i can "T" into my vacume advance or does it need a TVS before it hits the carb? currently the EGR is just capped.
The EGR is timed so it'll only come on when you're at a crusing speed Don't "T" it into the vac to the distributor.
where should i plum the EGR, or am i better off just leaving it alone? Thanks charlief1 wanted to ask before i did just to make sure.
If you don't have a vacuum diagram leave it alone and save yourself some headaches.
The diagram on the shroud is ledgable but it hard to make sence of it for me:frown: just the thought of the EGR going no where is on my too do list with alot of other things:redface: but still no headaches yet!:)
You need the correct sensors hooked up and the switches need to be there as well.
