EGR & Wastegate Solenoid ?'s
scrobbyd
Just curious as to if I need my EGR solenoid since I now have no EGR valve. If so, should I just block off hose port on solenoid and leave plugged in and T in to another hose elsewhere? Same question on the wastegate solenoid since I now have RJC boost control from wastegate to turbo. Really I'd like to know what all can be elliminated as for as all the small hose go.
Thanks in advance
Took both of mine off. Also took out the charcoal canister. Much cleaner engine bay and zero issues with any of them being deleted!
Just curious as to what you did with plugs that go on to each of these?
If you have a TurboTweak chip you CAN unplug and remove the wastegate solenoid. Same with the EGR. Not sure about the other chips out there.
