Electronic boost controller
That will depend on what you are wanting the controller to do.
I am using the Boost Leash and am happy with it. Available from Hartline Performance...
Bryan
I use a boost controller that's no longer being made (Innovative MSMC). It tends to spike a pound and 1/2 high for a fraction of a second before it comes back down to settle rock steady at it's set point. I understand there is a trick fix for this little annoyance. But I haven't had the time or the need to address it. It doesn't matter one bit though. Because for me almost anything beats having some compressor style turn-knob or guessing rod length on some wastegate actuator.
I'm going to assume that any of the above mentioned new boost controllers will be even much better than this. And also be a pleasure to use as opposed to mechanical methods.
Now all you have to do is determine what features and options you need them to have............and also cost.
