Energy suspension or Prothane body bushings?
evil666
I was wondering which polyurethane body bushings should I get, Energy suspension or Prothane body bushings? I would like the opions on either ones if any of you guys have used them. If any of these bushings squeak I would like to know, and I don't where I read this but could one or the other come with sirts (sp?) to grease them?
Thanks ahead of time,
Marco.
T-Top 86 Grand National (61400km)
stock long block, stock suspension, 12 inch red stripe convertor (2800stall), te44, smc alk injection (95 % etanol), 25.5lbs boost,( boost spike 28 psi in 1st gear), 94 octane, hooker cat back with dyno max ultra flow muffers, 42 ½ lbs 009 injectors, turbotweak alky chip with 23/21 timing, thdp, mease 24 row IC, Ron Custom max boost brake module, MT drag radials (275/50/15) 3720lbs race weight with driver. (Torque convertor locked only after car shifted in third), rjc power plate, rjc boost controller, zeitronix wideband, HR motor mounts, comp cam 980 valve springs. Weld Drag Lites with skinnies up front, electric exhaust cut-out.
BEST E/T
60FT=1.53
1/8= 7.25
1/4= 11.48
MPH=120.82
BEST 60FT=1.52
Shiiiip, wish I knew about Prothane, looks like they're half the price of the energy kit. Someone better speak up and say that brand is garbage! :p
Anyways I have a box of Energy bushings waiting to install this spring. I've heard lots of people who use this kit. Haven't heard about that other brand before.
Edit- Nevermind, must be getting tired. For some reason I thought the energy kit cost me $220. It was only $120. So there isn't much price difference. I think I'll go to bed...
Hi,
When it's half the price, think China. I've seen some real crap that was made in the USA, but you can almost bet on it, when the Chinese are involved. This will change, with time,but we don't have so much of that, anymore.Ask your supplier what their source is. Moog is my favorite,always top of the line stuff. I am not sure if they make body mount bushings anymore,but you can bet they were a supplier of the originals. Good luck with your descision.
Hi,
My Energy Suspension bushings say Made in USA right on the box ;)
i bought a set of prothane, just put them in radiator support fit good, look good.i'll put the rest in the spring.
