SignUp Now!Clips are all good,I will check plugs I have one rusty and loose wire on coil side could it be that??? I will put new end. Seems like the hotter it get's the worse?? I don't know. THANX KERRY
I have a 12k GNX WITH 50 lb injectors, 49 turbo, converter, ?down pipe, and some other mild boltons and sometimes it runs mint but other times under low or high boost it breaks up. Any ideas or help?? #774 696 3585 THANKYOU KERRY
