Engine Gaskets...
my1stgn
Looking at rebuilding the engine soon so I wanted to see what type of gaskets everyone is using. Im going to need oil pan gasket, head gaskets, valve cover gaskets, and Ill probly end up changing th front and rear main seal. They are all leaking a little (some more than others) and I wanted to try to prevent this but wanted to know which gaskets/seals are less likely to leak. Thanks in advance!
Use the cork oil pan gasket,I use the rubber v cover,Use Felpro head gaskets...I tried ROL and they blew with no knock and 17#.
Here ya go, you can't beat the price, the only thing you need is the valley pan/intake gasket.
http://www.fullthrottlespeed.com/items~CartId~{3DF2CEVERESTEF1-96CD-4AF2-8108-D46933E5A127}~Cc~BUGASKET~iTpStatus~0~Tp~~Bc~.htm
HTH
Prasad
