engine noise
3.8 LA LEY
Any idea what this could be ? Sounds expensive
I can tell you its not the converter bolts.. just finished checking them.
Sounds valvetrain related. For starters pull the valve covers and look for loose/broken rocker arms, anything that might be loose or out of place.
Yeah sounds expensive. Oil pressure getting lower over time?
Hard to tell from a recording, but unless you can definitely tell where it is coming from I would take the accessory belt off and start it just to rule a bad accessory or rattling belt tensioner. Then start looking internal.
Details on the engine?
Balancer loose?
Converter bolts tite and the flex plate loose or cracked?
Oil filter cut and inspected?
SM readings, data logs?
Plugs look like?
I thought I had big troubles deep in my motor and when I started the disassembly I noticed a witness mark inside the driver's side valve cover where a rocker arm was lightly tapping it.
A slight adjustment of the valve cover is all it needed!
If it were mine, what Nigel said above is where I would start.
Ed
all the rockers are tight, I'm thinking I might of cracked my flexplate. have to lift it up and do some digging
Keep Lifters in mind in case you get deep into things and nothing shows up, it almost sounds like a few are possibly not pumping up under load.
almost positive I spun a main bearing....
oh well stroker kit here I come
what's weird is that I wasn't beating on it or anything just some pulls here and there
Now the real question is if i do a Stroker do I leave my 6266 or upgrade to a 6466 probably need to swap out converter too
What leads you to believe you spun a main bearing?
Oil pressure loss?
Did you cut the oil filter open and look for bearing debris?
did some digging… bearing 2/3 decided it was time to part ways and said there goodbyes
looks like I’ll need a valve job too
so this is the plan:
Send the turbo to precision to verify if there's any material in the cartridge (if so I'm screwed because you cant rebuild a DBB turbo)
Eagle stroker forged rotating assembly
RJC Girdle
compression I want at 9:1
switching over to hydraulic roller and went with a 212/218
I was going to do the billet mains for 2/3 but for my goals of 600 to the tire, the girdle and forged internals should** hold (not really going to the track this is more of a nasty little street car)
again mainly this thing will 90% be driven on the street and will rarely ever see a track just want the 600
some info on the car
E85
holley terminator x max/cruz harness
ls coils
cruz headers and DP/precision 46mm external wastegate
4l80e tranny
champion irons
6266
double 34's out back
eric's 120lb injectors
racetronix fuel lines
I also thought a ball bearing turbo could not be rebuilt, but friend of mine just had one rebuilt by precision
Well damn that’s good news…I’m sending it out tomorrow let’s see what they say.
Did he mention around how much they charge?
