Well Syd is down and is going thru a refresh. Well I was told that a NASCAR team (Petty Enterprises) went thru and put a few nascar tricks in the block. Well to tell you some of you may have seen this but this is a first for me. The block has oil squirters built into the mains of the block and the mains have small groves cut into it to feed the oil squirters. The purpose of this as I am told is to pull heat away from the piston to help in cooling. The way it is in there look really good and looks to be a .002-.004 groove cut into the mains. With the main bearing in place it helps direct oil UNDER the main bearing to the groove. Probably the ONLY 109 like this. Motor has great oil pressure, check it out!! Kewl lookin!!
