First want to give Otto of Otto's Performance a big thanks for hooking me up with the Moser stuff. If anyone needs axles, housings or anything else, contact him for the best prices.
This is what UPS dropped off. All Moser stuff....Fab 9 for the G-body, aluminum thru-bolt center section, spool, 40 spline gun drilled/star flanged axles. The axle ends are Big Ford-old style. Moser does powdercoating but the axle was ordered bare because I need to weld the brackets for HR bar and tabs for the brake lines. The housing is going to be powdercoated after the welding is done.
Here are some weights
- Housing............ 65.2 lbs
- Center section... 60.6 lbs
- Axle................. 16.4 lbs
- Axle................. 17.6 lbs
Total.................. 159.8 lbs
Billy T.
gnxtc2@aol.com
Billy T.
gnxtc2@aol.com
