UPDATE...... Sorry for the delay. I want to finish this thread. The Moser housing had some issues which I had to correct. This is for your information so you know what to expect. The guys at Moser were not much help, either.
If you are going to install a HR bar on the housing with a backbrace, the bolt that holds bar bracket needs to be welded to the mount bracket. Once the bracket is welded, there is no access to put the bolt in.
Here are the issues I experienced:
The sleeves on the upper control arm were too long to fit a spherical bushing in it. Also the ID of the sleeve varied. I was able to push one bushing in while the other had the proper interference fit. Soooo, I had to cut down the sleeves with a band saw.
I spoke with Moser and so did TRZ and Paul (HR Parts) about the length and ID of sleeves. Moser's response was the that they make the rear for OEM bushings. I told them how about offering an option for the racers? They couldn't answer me.
Next issue was that the lower control arm brackets were too long. When I went to put my wheels on, part of the bracket hit the wheel. The fix was easy by cutting off approximately 3/4" of the LCA corner. I called Moser and told them that the bracket were too long. The idiot told me that I needed to buy different offset rim. I replied back to him then I have to change the length of the axle tubes/axles, he couldn't answer me.
The final issue was when my chassis shop (JW Racing-Fab) squared up the rear, it was shifted to the passenger side approximately 3/4". I was able to loosen up the boby bushings and shift the body slightly. The other way the rear could be shifted if all the control arms are adjustable. I could shift the rear was due to the solid length LCAs. I believe that Moser's jig is off. Previously I was running a Moser 12 bolt with no issues. Sorry no pics.
IMHO the it is a nice piece but if I knew off these issue before hand I would have corrected them before the housing was powdercoated. When I go PRI, I will voice my issues with them.
Some finished pics
