buickshake87
- Sep 25, 2010
One of the drawbacks to this section is it doesn't always get a lot of views. You have an issue with the IAC and/or TPS is what it sounds like to me. Do you have a scan tool of some sort so you can tell us what kind of readings you have.
Hooked up a SNAP-ON MODIS to the car today and it showed no codes, very weird the way it acted though.. went into display data on the MODIS and the car started idling correct at 1000rpm, then backed out of the monitoring data screen, as soon as the MODIS said disconected, the car went back to idling like crap, rpms droped, started missing again (all which are the normal symptoms this car displays) then went back into the program again, car cleared right up. Did this 3 or more times exact same result each time... anybody got a cheap modis i can just lay in the floorboard and leave hooked up?????????????
