Fan relay question
Turbo Keith
TURBO KEITH
I removed this relay due to it making a " Clicking " noise after I killed the car and didn't want a fire some time back . My fan comes on with this relay gone but I'm thinking bout upgrading fans . What does it do if ever thing works as it should ?
That's the fan delay relay, leave it unplugged, usually end up kicking on at odd times even when the car is cold, draining the battery, and stranding you needing a jump start.
That fan delay relay was one the good ideas but a flaw in GN’s. Many say jus take it off and throw it away. They also say it eventually does more harm than good. There’s a lot of threads about it. All it does is keeps the fan running after the car is shut off. The reason for it being a flaw is that the relay was not sealed from factory soo thru the years it starts to rust and goes bad
