Craig/Lance et al:
Putting in a FAST in my car. Planned to use alky as well. How do you suggest I set the FAST up so it doesnt compensate for the alky. Should I set it all up in closed loop, then run open loop with the alky? Can I use the NOS output to trigger ther alky and then is there a setting to not adjust fuel? If using the NOS trigger, should I set NOS enable to OL?
I only intend to use the alky for the street, I'd hate to waste a WB O2 by running leaded fuel ALL the time
