fast log file looks choppy
tubby
would anyone be willing to look at one of my log files? some sensor info looks very choppy but i've only ever seen mine so i don't know if it's normal. i'm not sure how to attach it to a post but i could e-mail it
thanks
Looks like your logging 20 frames a sec, over a long period of time, yes it does looke choppy. Also looks like your running out of fuel somewhere the duty cycle is almost 90% at times with only 15 psi boost. I don't see any gear changes in the log either. The a/f and rpm is all over the place.
Try doing a 3rd gear run full booost, and log at 10 frames a sec for about 10 secs, might clear some of this up.
make sure the box is getting good grounds back to the battery and 12v+
thanks,
fuel problem has since been fixed. i will double check the ground and change frame rate. the shifts hardly show up as i think i'm on the edge of running through the converter.
