I'm now using the WINDOWS version (1.005) and I'm having some issues with the Spark Advance table bubble.
When viewing the timing table, the bubble indicates 1/2 the RPM's tag reading. The indicated RPM on the bottom of the screen is correct, just the bubble is off. I'm using a 400 cell width and if I rev the motor to 1,000, the bubble is just past 400 (by the table's legend). I can take it up to 3,000 and it's right at 1,600! This is not the case when viewing the VE or AFR table. They both read exactly what the TACH says and what is RPM tag says.
I've changed the table size both UP and DOWN, but it still reads 1/2 of the RPM's tag. I've ended the WINDOWS version and started the DOS version, and everything is reading correctly.
Is this an isolated problem that I'm having or is there a BUG FIX that I've missed?
thanks / Bobby
thanks / Bobby
