I am using the 3 wire harness and I had the white and blue wire going to the a6 but the fast xfi wasn't reading,Hey there, I just re-read you post. You bought the newer version..... So that model does connect different than mine. Are you using there 4-wire/3-wire harness? Do you have the WHITE/BLUE to A6? But I am surely positive that you need the green output of the flex sensor to go to A6 and Zeitronix...... If you didn't have the Zeitronix, you would be just running the Flex output to A6.... The output (white/blue) is probably the wire/output that runs to your gauge.
EDIT: Do you have the flex fuel bottom turned on?
so I did what I think you told me, was to split the green wire coming from the flex fuel sencor. One going to the Zeitronix ethanol content analyzer and the other going to a6 on the fast and now I disconnected the white and blue wire from the a6 and left it alone, but that still didn't work. Now I hooked only the green wire to the fast A6 and I think I am getting somewhere, cause I read on the fast but I can't use the zeitronix digital gauge. I am trying to get in touch with zeitronix to see if they could give me a helping hand.
Marco
