cylinderhead101
 - Aug 30, 2004
I'm currently running XFI with 2.01. I'm using a Casper's adapter harness to plug into the original Buick harness. Here's where I'm stumped...the car will crank, run, and idle. I've already set up some base timing tables. Crank reference angle is at 10 degrees. The bubble floats around on the timing tables and the laptop shows timing should be moving. I've checked and unchecked the fixed timing box trying to get something to move. My problem is this...the car is running at ZERO degrees timing when I check it with a timing light and IT WILL NOT MOVE no matter what changes I make in the XFI. The XFI shows the timing to move on the table. Also, I can see map voltage and TPS voltage changes in the XFI. The inputs are there. The timing at the balancer DOES NOt correspond with what the timing tables show and will not change with changes in the XFI. It runs at zero and glows the headers. The light is correct. The mark is correct. I've had FAST run diagnostic on the XFI and they state it has no problems. WTH? Anyone have any suggestions before I buy a box of matches. LOL
