SignUp Now!Here is a thread on hypers.
Hope this helps.
http://www.turbobuick.com/forums/engine-tech/249263-speedpro-hyper-pistons-any-good.html
Thanks all the same but saw that before....I want to see the numbers.
But on a side note they seem to live better when being sprayed w/ alky.
My bad bro. :redface:
If you were interested in "slowest", I could give you some solid numbers.
I ran 7.06 1/8 at 98 with a 1.56- 60ft and plan on going 6.70 next time same piston and a stock block with no main cap just rod bolt
... Imo they are not ideal since they will hold more heat in the combustion chamber vs a eutectic ...
Factory is cast eutectic. Hypers are cast also and have 11% or more silicon which makes them expand less, have a higher melting point but are more brittle.Could you elaborate on that? I thought the OP was talking about hyper-eutectic pistons. I know that hypers and cast pistons are cast and that the hyper-eutectic has more silicon (if I remember right) in them but is there another type of eutectic piston commonly being used?
