Fastest Pump Gas / Alky Cars (updated 10.07.18)
highly recommend a rev limiter with ignition cutout of some sort, I made the same mistake when I forgot to move the shifter out of 1st gear and luckily the limiter caught it. Yours appears to be in 3rd gear which means it was 6500+ for an extended period of time instead of quickly. Also appears to have maxed out injectors so your lucky!! Thats double trouble....
JD, I'm trying to get mine out of the tranny shop and head to the track. LOTS of carnage this time.
Were the stator support bolts loose? I wouldn't reuse that converter.
Me, in the left lane. Got a little handwritten warning too.
he says he was warned ...i think when she wrote slower on his slip she was referring to me in the right lane ..blew the tires off just after it left the line and didnt get them back till after the 330 , still took him by about three cars ..theres an in car video somewhere as we were both running action cams mounted on the rollbar
theres a lot left in his car ..boost was much lower than most would think for an unported gn1 8bolt head / 234 cube /109 /xfi 2.0 /th400 running on the MT pro 275's
he's full caged and its certified so it time to start making some license runs so he'll be legal to turn it up at etown . until then theres a track rental at end of month and i would expect him to move further up the list
congrats again scotty you really moved up on the list and even further on the 1/8th mile list as well
that was me , i was only going for an 1/8 et and trying to keep the 1/4 et slower than 10.0 so i had the boost controller set to drop boost to 23 psi after 6.5sec.
it didnt :) , could get a grip on the hit and lost .5 in the first 200feet
times are in the pic murph posted of the slip and his 6.243 at 109 knocks JD down a peg on the 1/8 list
Way to go GUYS!!!!!
Can't wait to have all these cars at Bowling Green!!!!
Great job LOOK FORWARD to lining them up!!!
Got a few surprises coming SOON!!!!
You guys just made my weekend with those video's....
Thanks for sharing..
