PTSDarkness
- Apr 1, 2013
Hey guys, I am getting ready to do a LS turbo swap and figured I would put a feeler out there to see if there is anyone that would like/NEED any of the parts or all of them. Kinda trying to help out other people ya know. Any how here is what has happened.
1984 Olds Cut Supreme, AlmostCOMPLETELY converted to a GN minus the body panels and bumpers and such. I bought it from someone who had done all the work except the alcohol kit was home made and it failed. Needless to say it happened on the FIRST pull on the Dyno a little while after I had bought it. The motor sounds fine at idle. Its when you apply fuel (give it gas) when I could here the knock. So I pulled the oil panand sure enough it will need new piston rod bearings before any body goes and plays with her again.
I can tell you that the motor IS all factory internals based on the head bolts still having the paint lines across the heads of the bolts and they haven't been touched. I could just order a rebuild kit from Summit Racing or some other place. but the way I see it. I want much more power with a OBD2 system. I am going to try to load the pics here and see who is interested in it. If no gets serious with it I will just keep it as a back up. either way Im not that worried ya know.
Stock 3.8L turbo Buick w/polish bigger plenum and throttle body
Bigger Exhaust down pipe
Precision TE44 Turbo
2004R built trans works GREAT (I dont recall what the name is but I know I looked it up a awhile ago and it is on the rarer side of things from the factory compared to other 200R4's)
Wiring harness for 1986 Buick Grand National and PCM with (3)chips from "TURBO TWEAK"
will be removing the A/C entirely
Will be removing the Heater entirely
As well as ANY and ALL unnecessary items that take up weight or room for the LS and her Turbo. ALL OF the ITEMs are also available locally where I live so it is first come first who has the CASH! The big items are pick only, unless you desperately need it and can make it worth my while to get my disabled butt to go somewhere else. Please feel free to ask any and all questions regarding this. I will do my absolute best to respond to you in a timely manner. and if @ people ask for the same thing one after the other here I WILL contact the first person that appears in the forum requested "SAID" item/s.
