Fel-Pro 9441PT Gasket Problems?
This statement is grossly inaccurate; a side by side comparison shows a noticable difference in the fire ring construction with the advantage going to the Victor-Reinz which makes them for GM. So GM and Victor are the same, and Felpro are their own.
Grossly inaccurate? According to you I'm 66.6% right. What would slightly inaccurate be?
A 100% accurate statement would be that I've blown all of them up and it would be grossly inaccurate to say that the gasket was at fault.
I've been using the Fel-Pro 9441 pt gaskets for many years without any problems. I do try to keep the tune safe and only run 22 psi boost on the street.
Rockauto has the Fel-Pro 9441 pt gaskets for $28.00 each. A set would cost me $63.00 total shipped from them.
I have Cometics and my mechanic said the pass. side is leaking outside. I posted this problem and others have said to use sealing tablets that go in the radiator. I questioned my engine builder about retorqing them and he said he never does. I was told that if I retorque them now, I would break the seal with the silicone or whatever is used for sealing. I have ARP head bolts. So I will try the radiator tablets. Don't mean to hijack this thread but does anybody have any other suggestions? Any other experiences with Cometics?
Cadillac tablets worked for me.
Wow, we dug this one up from the dead. I can't remember what I was doing when I pulled the heads off for this thread, but I can say I went with GM gaskets for my stroker build and haven't had any issues.
