696
- Jun 11, 2009
Ok, got the system on (all 84 replacement parts). I have the "brake" light on the dash but if I move the E-brake a little toward the floor it goes off. Did the hydroboost system mess up the adjustment (if there is one)?
The 1st half of the brake pedal is GREAT, barely push and it stops great, the halfway to the floor seems a little more spongy (yes I can push the pedal all the way to the floor). I can slam on the brakes and get a lock up but sometimes it slows quickly but will not lock up and it is NO WHERE near as solid as the 1st half. Air in the lines still or is that the way the system works? I did bleed the brake lines til the fluid was the new clear brake fluid but only really got air on the pass rear cylinder (the 1st one we bled). I bled the power steering system by working it side to side and I guess the air is out (no bubbles). The only other thing is I hooked the system up 3 days ago and filled up the brake and power steering fluid then it sat til today when I bled both systems.
If the system is suppose to be this way fine but I want to make sure this is the way it's suppose to be.
Thanks,
696
Thanks,
696
