Basically wondering weather ported heads are right for me. I am looking into ported heads so I can run lower boost levels (run lower octane on street), yet still put out reasonable power.
Ok, I have all the little BS that the car needs such as Walbro 307, hot wire, gauges, friend has T-link, fuel pressure regulator. Right now, I am running the stock turbo/IC/Injectors. I probably will be for quite a little while.
My future plans call for a TE-44. It will take me as fast as I want to go. This is a While in the future, probably a year from now. Is it sensible to get ported heads now, before the turbo? Will it give a reasonalbe improvement with the stock setup?
I have a set of bluetops that I haven't put in the car. I know the TE-44 will work well with these, but I have heard that the 36lbs are too small injector with ported heads. Should I try and sell the blues, and go for say 50's ?
What kind of times would I be looking at with TE-44, ported heads, 50's, at say 18-19 psi? Would I get the same times with unported heads and say 22-23 psi?
Also, what about the cam? Is it safe to run ported heads with the stock cam?
I know I'm all over the place here, but thanks for any help.
