My Hartline hood is so detailed that there are still "spot weld" marks in the outer flanges where an original steel hood halves would have been spot welded together. The rear trim piece is molded in with the hood. The underside if finished and cut out like a stocker. When painted, the only way to know it's glass is where you can see the underside of the top part of the hood. With a hood pad in place you could never tel. If yours has that much detail it's probably a Hartline.
