SignUp Now!What would be the final lift of a cam with a .587 lift using 1.65 ratio roller rockers?
Just wondering;
Why would you want that much lift, Ass-U-M-ing this is on a V6 Buick motor?
This would be on a stage 2 4.1 274 cu in motor with gn-1 heads-224/224 roller cam. i figured it to be about .625 using 1.55 as a reference point or .675 using 1.50 ratio as a reference point. this cam is a custom grind that had already been in a street driven 6109 block but was too much for the 3.8.
I could see it if he was running a solid roller... but a hyd roller may create valve float problems with that much lift... That's the whole reason I took the 1.65 rockers off my motor and went back to 1.55's.
I would have to see the cam card to know if the cam will work well or not.Thanks for all the advice. Bison does having the lobe seperation at 112 help at all. ?
