Now on to more work. I spent most of the day in the shop doing the disc conversion on the rear and I can tell you one thing. Make sure you know how to sharpen a drill bit. I ruined 2 bits on the flange for the backing plate and had to sharpen another one so I could finish the job.
I started on the passengers side and I had to figure out what I wanted to do and how. I started by cleaning the rust off first, then painetd the area white so I could see the lines easier. I followed the directions that have been posted on line and added a little for mistakes. More than I needed in the long run but I wanted to make sure I didn't screw up. After the first cut I tried fitting the backing plate on and had to do some more trimming to the flange. The biggest issue is that GM made a ring around the Camaro flange that's not there on the Regal. You must do some measuring to get it centered. Not that big a deal but you have to be good at spacial referencing so you can get it centered.
Once I got the flange cut right I found that the two original bolts were just long enough to hold the backing plate on so I could mark the location for the upper bolts. Once I drilled though the two upper locations I put the bolts in and drilled the lowers. BINGO! This isn't that hard but it does take some thinking on how it needs to be done. Do your research on how to make it work and it will be fine.:biggrin:
