54Rich
- Apr 10, 2007
I just wanted to Thank Everyone and I mean Everyone that helped me get this car on the road! I'd like to mention names, however, I'm sure that I'd leave someone out and I don't want to do that. I only got ripped off once
and since he has not cashed the check yet, I guess I can't call it totaly ripped off (Kenny where the heck is my shifter handle?)
I bought this back in May and it didn't take long to realize that it needed, love and money. I can finally say (At least for now, LOL) that it's down to a heater control valve and a turbo that does not double as a bug fogger. Both parts are hopefully in the works. Also, adding a ScanMaster so I can tell what's going on with it. I may get to drive it before it gets put away for winter!
I bought it from pictures and a discription from a member here and he came through with his commitment to me and I appreicate that
I should have went and looked at it first and in person, but thought can't be that much wrong with it
. I bought a rust free, running T. Here's what's been done to it:
1) New Tires - Rears have 5/16 spacers- Sumitomo HTRZ 225/55R 16 and 255/50R 16
2) Posi Rear
3) Longer Wheel Studs
4) New brakes
5) Repaired Stereo, replaced 4X10
6) Cleaned and repaired Speedo and Trip
7) Oil Change
8) Radiator Fluid Change
9) Installed 160 Thermostat
10) Repaired dash plate
11) Replaced Dash
12) Repaired AC, replaced Compressor, dryer, orfice, charged
13) Replaced Carpet, Headliner, Visors
14) Replaced Supertine Belt
15) Repaired PW Pump
16) Greased and Lubed
17) Replaced Trans Lines, added sheilds (Missing)
18) Cleaned Intercooler
19) Replaced Intercooler Brackets (Missing)
20) Repaired Windsheild Washer
21) Replaced Speedo gear
22) Replaced Brake Resvior
23) Replaced Amber driving lamps
24) Replaced Air Dam, both sides
25) Installed rear seat braces
26) Repaired Tail lights
27) Installed correct shifter
28) Replaced shifter inlay
29) Painted rear wheel trim and installed
30) Replaced Vac lines
31) Replaced gas tank
32) Upgraded Fuel Pump XP
33) Installed Hotwire Kit
34) Replaced windsheild blades, painted crowl
35) Removed Pass header, cracked (due to missing intercooler brackets) Replaced
36) Replaced rear seal, oil pan gaskets, valve cover gaskets
37) Replaced motor mounts, trans mount
38) RJP Power plate
39) Replaced heater control, vac switch
40) Charged AC
I'm sure I'm missing a few things. I can now say that I know a little about these cars. I have 5 miles on it since I got it running, don't like that Turbo, way to much smoke. Put some 93 in it and seems to pull really hard. I have no idea what the chip is or if it's matched to the injectors. Can't wait to get the Scanmaster and start tuning
Again, Thanks ALL!
To be continued.......
Rich
2) Posi Rear
4) New brakes
7) Oil Change
11) Replaced Dash
38) RJP Power plate
40) Charged AC
Again, Thanks ALL!
Rich
