the 87 gn (turbo regal) and gnx motor only differed by the turbo, the intercooler fin count and the chip
that said the tta and the gnx are far from being the same
the two engines though they share some of the same parts like block (109), timing cover intake plenum fuel rail and injectors ... other than that they arent even close
PAS was responsible for building the TTA motor for pontiac and although its based off a buick 3,8 intercooled motor its unique enough that its a pontiac motor as they paid for the research and build as well as the packaging into the fbody
the tta had different heads (from fwd car ) , different valvecovers, rocker arms and headers due to heads ,
the tta block though it was a 109 block it differed from the GN-GNx 109 as the tta was also cast with SG1 on the side
the TTA internals had a crossdrilled crank ..the gn-gnx did not get that crank
the tta pistons were different from the gn-gnx to fix the compression because the fwd head cc was different than the gnx 8445 head
the tta had a totally different oil cooler from the regal .. the regal routed oil through the brass radiator oil cooler , the tta had a std f body radiator that only had trans oil cooler so they routed coolant from the radiator to the oil adapter , the TTA oil cooler also relocated the oil filter to fit the chassis and had an oil pressure gauge mounted on a special oil cooler adapter nut that held the cooler adapter to the oil pump
the tta intercooler had the same fin count as the gnx but used a differnt intercooler shroud
the tta received the same turbo as the Gn and other turbo regals
