Hi all,
I changed my transmission fluid in my 87 Turbo Buick as part of my spring cleaning and upon taking her out on a test drive afterwards the firm shift that I once had has noticibly gone away? The fluid I used was GM's latest Dexron fluid as I understand that it's backwards compatible, when I changed the transmission filter I elected to re-use the 2 o-rings from the old filter vs. the lip seal that came with the new filter.
Any thoughts of what might be the issue?
Tommy
Tommy
