To unstand some history, check my other post. I'm starting this thread specifically on the O/H of the BRF I just pulled from my Z28 to put in my stock 87 GN.
First of all, I wasn't planning a full rebuild since it was running ok, but wanted to make sure it had the nessisary hard parts (pump ring kit, stator, sun shell, l/r bearing) and check endplay. I decided it wouldn't hurt to put the B/W clutches from a previous rebuild kit seeing as I won't really need them for the other tranny. (I posted some pressure readings in another thread)
Shift kit: I previously put a new style transgo repro kit (full race) in it, I was planning on leaving that. Is there anything I should revert or change from that kit?
Valvebody/Gov: BR3 valvebody, governor is definately a GN type. Is it correct to have no spring on the heavyweight side?
Pump: body is 690, stator splines are shot, can't tell if the rings are hardened but I'll change them anyway. I will drill the drain back holes. Should(Can) I put a 10-vane kit in it? Or is that best left upto you guys with the milling machines.
Checked the input shaft endplay and it was .035-.037", and the fwd clutch shaft end play was .048". The sunshell doesn't looked hardened. So I'll put in one to be safe. I am down to the L/R clutch so far...
