NHRA Super Gas
- Nov 18, 2005
OK, it's 50+ degrees in Chicago and I've had my car for about a month. Had to get it out there and see what i've got. Here are some thoughts/questions for the group:
1. Scanmaster Recall: I punched it dozens of times, checked recall at least 6-8. Only once did it register knock (2.1). Also, AF voltage seemed like it could be low at times, 735 at 90mph was one instance that comes to mind. Others it seemed to register like 225 but I figured that was a glitch to be ignored....This was at 22lbs boost with 100 no lead. Also curious what happens to these numbers in June when it's 80+ degrees outside.
2. Transmission: Seems like you can really feel the car jump in and out of lockup, and it seems like the shifts are very crisp. I did not think it had a shift kit, however I could be wrong. I'm assuming the herky-jerky ness is a combination of lockup and 3200 converter. Anything else I should check for adjustment, etc?
3. Oil Pressure: At moderate or WOT it was fine, but seemed low in drive. At a stoplight for example it was around 15psi. Everyone else see similar numbers?
Otherwise, it seems like a good piece. Feedback is appreciated.
TIA,
Eric
TIA,
Eric
