Went to the local drag strip today, made 3 runs, and i'm pretty happy. Best time was 13.11@106.3, best mph was 106.69. 60 fts were pretty bad, 2.1 leaving at 5lbs of boost spinning bad. Had the Nitto drag radials @ 21psi, and a good burn out. Car has the following mods: Joe Lubrant street chip 18psi and 22degrees of timing, no cat converter, hooker exhaust, K&N cone, 160 stat, 36 lb injectors, ADFPR, scanmaster, AD Wastegate actuator, 275/50 Nitto drag radials. Stock turbo,intercooler, heads, cam. I didn't lock up the TC, so without doing that, and the weak 60ft's, I'm pretty happy. 02's were 810 and 0 knock.
