1. The Overdrive backing plate measured .196" (suppose to be .210") is this ok?
2. I have .062" clearance between snap ring and backing plate in overrun assembly. (top of OD indeed measures 1.400" from plate)
3. The direct clutch housing backing plate measures .176" (suppose to be .210")
4. Direct clutch clearnace measures .070" (suppose to be .030 - .065")
-So because of the plate and clearance, all I need is a plate that measures .210" right? This will get me within the tolerance?
5. After getting the direct drum assembly all together and air checking on the center support, I notice there was quite a bit of air the seemed to be comming up right out the middle. After playing around with it and pouring fluid all over to see bubbles, I determined the air is getting passed the space between the top bushing and race of the support/drum. Is this normal? or is the ring not sealing? I also noticed that if you put pressure on the outside of the drum at different places, the air will come out correspondingly at a different place around the bushing. (dual feed modded, middle ring removed, seal removed, bleed hole drilled per ck book)
6. One more nooby question, the steels for the directs, these have two spots where some of the teeth are missing. Do these need to be orientated a special way or just throw in the any which way?
Thank you so much for all your help.
