Sep 27, 2015 #1 T tsm3089 Member Joined Nov 11, 2006 Messages 285 Who has a gm flex sensor with the sd2.
Sep 27, 2015 #2 dank GN BlackArts Automotive (661)993-8277 Joined Jan 11, 2009 Messages 4,039 I do pics to follow
Sep 27, 2015 #4 T tsm3089 Member Joined Nov 11, 2006 Messages 285 dank GN said: View attachment 263462 View attachment 263463 Click to expand... How is that sensor wired.
Sep 27, 2015 #5 dank GN BlackArts Automotive (661)993-8277 Joined Jan 11, 2009 Messages 4,039 through your old MAF wires . I believe its 5V , signal, ground
Sep 28, 2015 #6 T TurboBob Resident mad scientist Staff member Joined May 24, 2001 Messages 6,677 12v, signal, and ground Bob
Sep 28, 2015 #7 T tsm3089 Member Joined Nov 11, 2006 Messages 285 gm 13577379 sensor i have left to right looking into the connector. ground 12 v signal
Sep 28, 2015 #8 T TurboBob Resident mad scientist Staff member Joined May 24, 2001 Messages 6,677 I don't have the pinout order handy, I was just posting to clarify that the sensors are 12v powered. Bob
Sep 28, 2015 #9 E Eric Stage I TurboTweak Guy Joined May 25, 2001 Messages 2,676 OUT is the output signal that goes to the ECM's MAF input GND Ground Vcc is 12v ignition supply
Sep 28, 2015 #10 B Boost231 What's An Intercooler Staff member Joined May 26, 2001 Messages 16,741 Where can I order this sensor? How much is it? And a pigtail?
Sep 28, 2015 #11 T tsm3089 Member Joined Nov 11, 2006 Messages 285 sensor can be bought at summit amazon pace ect. $65.00 . pig tail from gm # 19301582 $ 21.00 You will need fittings if used in a braided line also.
Sep 28, 2015 #12 B Boost231 What's An Intercooler Staff member Joined May 26, 2001 Messages 16,741 These fittings will work for the ends right Aeromotive 15118
