Flow meter for Razor kit?
Jer
Snow Performance now offers a flow meter with a set point to disable electronic boost controller to switch to low boost or whatever you want to do with the output. It's called 'Safeinjection' & costs about $100. I was curious if this was in the works for the Razor kits?
Problem is the fittings on that box are hard to adapt to the razor kit.
The other problem since the fittings may/will be an issue.. if you blow the fitting of the pressure side you will have lots of flow..but none into your engine.
All the newer kits as of late last year have pressure sensing. This pressure sensing is to be used to monitor the system. If there is an issue.. the response of the pressure sensing will show it.
Maybe another way to state it.. I have not had any pump fail that was built after Oct 2005 when the updates when into effect. Procedures have made a bullet proof pump.
If you dont have the updates.. I would suggest contact me off list
How do we upgrade to pressurie sensing?
Norbie :)
If you dont have the updates.. I would suggest contact me off list ;)
Right there :rolleyes:
Jason
tom j said:
How do we tell if we have the updates?
Pumps have dates with permanent markers, PAC controller has date as well.
Worse case you can always call me :)
