JDSfastGN
- Jun 16, 2001
I am trying to figure out which ones i would like to add to my setup. I run 17s so both are doable. My only ? is how much if any does each setup change how far the wheel sticks out toward the fender? My fronts are exactly where i want them, and im thinking that using the LS1 setup my wheels will be pushed out the same distance as a cut down stock rotor that is being used as the hub? Am i assuming right? This would probably push my wheels too far out? Ive heard the Blazer setup does not change this but wanted to get some first hand opinions. Thanks gus
