Here's some pics of the air filter ducting.
Nice looking setup, Don.
At what level do you think the single filter is a restriction? I was running into problems with my filter collapsing (imploding?) running a 70. Killed my MPH.
This is a 14 inch long air filter. The filter calc'd out to flow just over 1600 cfm at a 3" water pressure drop. My hp target for the moment is just under 1050. Engine airflow CFM will be maybe 1200.Nice looking setup, Don.
The intercooler is a different story. I did some calcs according to dimensions of the intercooler. It calc'd out at 725 cfm.
I was just gonna post this also,Especially if he is gonna keep theDon,
I think I already bothered you with this before.
Why not just dump the intercooler?
How much is it really helping with a full alky motor?
If you need a good source for a new, reasonably priced, custom I/C, lemme know. At 30psi I'm getting 54-59deg IAT's.
scott wile
I could use that for a house air conditioner !!
boost under 30,Which should be low 8s anyway.
Turn the compressor housing so it blows directly into the t body.
It will spool the best with no intercooler piping.
Less weight and less track maintenence also
Otto,
I know Don has run the numbers but I would definitely ditch the intcooler.
What is the pressure drop going to be like going through that core?
Most of the 2500-3000hp turbo alky motors do not have intercoolers.
I am not sure that I am going to argue with their success...
But... imagine what they could do with intercooling.
You're right. The intercooler does calc out to be too small. At my present level of testing (24 psi), I'm not worried too much about it holding me back. When I start pushing the boost, I'm going to start taking some pressure differential, and temp readings. I setup an access boss on the pipe before the intercooler for measurements. If it does turn out to be holding me back, don't worry. It will be eliminated or most likely changed out.At some point you don't want the fuel any cooler.
Since we think the the new turbo is too much for the
intercooler cooler, wouldn't any temperature loss be offset by
pressure drop? Just trying to think outside of the box.
BTW the air intake looks nice, please update us when you change
the hose out =)
Don these guys are running into the hard 6 in the 1/4 mile.I am SURE they have done their homework on this.
If an intercooler was gonna give the guys running at that level even .05 they would have one.
I know a FULL RACE GN that is NOT going to have a IC on it
You don't wont it but so cool...
