SignUp Now!Around 1300 but I've never really pushed this turbo. Always ran around 24psi with the old turbos but this one seems to really like about 30-35psi. Should be around 1500HP with ideal conditions which I feel is about the max for a V6.
FWIW - I usually just run Quick8, Pro-Mod, Outlaw, or whatever heads-up programs are running at local tracks when we go out. Got tired of being turned away by NMCA and other sanctioning bodies for being a turbo, a V6, tube chassis, etc, etc, etc. I just wanted to go FAST and be different. When turbos finally became politically correct, the rules started reading V8s only and I was told no V6's. I did run Nostalgia Pro Street a few years back at an NMCA event after a lot of politics to make an exception for my car as the rules didn't allow turbos or V6s. They strapped me with 3100#s to make sure I wasn't competitive and said if I came to a few events they would see about getting some weight off. I said thanks but no thanks. We all know they would cry foul if a V6 ever did become competitive and my pockets aren't deep enought to run with the like of what "Fastest Street Car" racing has turned into.
Good stuff Donnie. You make a good point about the autoignition issues. Conley experimented with the alky/NOS on his twin turbo BB Camaro right before he got out of it altogether. The goal was to get rid of the intercoolers/weight and pick up some HP at the same time. Never got it dialed in before he hung it up.
Heck, I guess I could just go straight alky and eliminate the radiator instead!:biggrin:
I use a tripod frame that comes off the front of the engine and supports the turbocharger weight from above it. Very similar to how F1 used to do it. I couldn't find a clear picture of it to post. I'll try to remember to take a picture of it to post later.Very beefy looking flange!
How do you plan to support the weight of the turbo? As I'm sure you know, it will cause stress cracks to your headers if you don't get the weight off of them.
The adapter is finished. I was alone at the shop so I couldn't hang the turbocharger on the car.
WIMP:biggrin:
WIMP:biggrin:
Use the engine host!![]()
