Bent6. I just re-read your first post. Your reaching 15 psi in 2 seconds. The first time I read it I thought it was .2 seconds. If you need that 15 psi quicker, up that shot size.
With your large plenum, you should be able to make an internal port injection system easily. Hang the system and put the thru-walls on the plenum cover.
I've got a single fan spray nozzle in the up pipe before the TBody now with roughly a 75 shot jet. It gets there pretty quick now before getting on the 2-step. I'm letting the XFI add a little extra fuel while the nitrous is flowing - shuts it off as soon as it gets on the 2-step. Your setup appears to be much more elaborate than mine.
What are you using for boost control? Your motor looks much more manly now with that 91
