Forced Performance Turbo Garrett 67mm Turbo
live2race
FPT67 Turbo
approximately 3k on it
The FPT67 turbocharger uses a 67mm inducer compressor wheel with a 75lb/min mass flow rate. The hot side is a P-trim T4 in a .82 A/R T31 4 bolt discharge turbine housing. The compressor housing is a T04S .70 A/R with a 4" inlet and 2.5" outlet.Like all our handcrafted race turbos the FPT67 uses the best bearing system possible, in this case that is the 360 degree SCREWED DOWN thrust bearing setup. The bearing housing is availble in dry/oil cooled only. Other turbine housings are availble, basically any turbine housing that exists can be fitted to this turbo, but you'll need to call to get those options.
cost $1045 new
sell for $750 shipped
CLVega@comcast.net
or
786 286-1395
Charlie
Reduced price
REDUCED $600
live2race said:
FPT67 Turbo
cost $1045 new
sell for $600 shipped
CLVega@comcast.net
or
786 286-1395
Charlie
turbo
the turbo, is a four bolt? or 3 bolt? if it is 3bolt. what is the cfm. and hp. rating. thank you. frank.
