T- Type Tim
Vice Chairman
- Jul 8, 2001
Going to replace moser studs with longer ARP studs later today
few pics of brake lines hung
SignUp Now!We've done silicone only, Right Stuff, a combo of those and a gasket, Copper Coat spray, the copper washers, loading the flange so the sealer squeezes out around the studs....NOTHING worked for more than 6 mo's.
few pics of brake lines hungView attachment 227275 View attachment 227276 View attachment 227277
No issues with shock mounts on this setup( quick performance)
I did do a search related to moser 9" and there were some problems with them in that thread
You will find some good info there
On the moser stuff
heres pic of the moser 9 " in my 87ttop with ridetech coilover
wolfe dbl adj arms and wolfe swaybar , added the HRparts lower frame braces
it have an HRpats swaybar setup for the rear and have perches welded for install so i might lose the wolfe bar and do the HR so i can get a decent set of tailpipes to fit
has torino drums on it which are so much better than the stock drums but those will be changed out shortly to the strange 4 piston disc to match the front along with a 4whl disc prop valve which should be arriving today
last thing im waiting on is the tall billet 1350 yoke from Quick
