Also impossible for them to reproduce the rolled fillets.
A forged crank does not have rolled fillets.
You may not tell it was damaged, but I could not tell my now broken crank was damaged either.
If it breaks, it will cost you at least 3 times what a new crank will, that is if the block is not damaged.
Also, you did not qualify how the crank/engine/car will be used? For street use only, good chance it will be ok. In a high RPM race application, I would not use it.
In fact, I will not put any used part for the rotating assembly in my race engines. The rods and pistons will only be re-ued on one freshen, then replaced with new parts.
I have seen hundreds of race engines, not only Buicks, destroyed by re-using parts of the rotating assembly, mainly rods.
A local Stage II engine was almost completely trashed when 2 "old" and expensive billet rods let go.
Everyone has their opinion, you have to make the final choice on how you spend your $$$$.
