Forward clutches
Sal Lubrano
What causes forward clutches and steels to overheat? Since they apply and stay applied all the time why would they ever go bad? I can see if a pump went bad and pressure dropped really low. Can they be over powered with stock pressures?
missing seals, nicked lip seals, low oil level
I think timing has alot to do with it
Off topic
buttered floor?that is what kentucky jelly is 4
You liked the buttered floor:biggrin: . I dont know what Kentucky jelly is for. Its next to the condoms in all the pharmacies.
You may have forward drum without a checkball capsule(meant for use with aluminum piston that contains bleed hole) and using a steel piston without bleed causing the piston to drag clutches when engine is rev'ed.
Kevin.
