Frame complete...
Update...
Are all the aftermarket bumper connector the same length ? Or are the fronts one size and the rears another ?
man that looks amazing , id powder coat the tips black as long as its black !!!
Will this car ever see the track with a sticky tire at any point? If so, your going to need to reinforce the perches just above the the strut. When I went to a coil over I was talking to Mike at TRZ Motorsports. He told me to reinforce the tops of the perches above the strut. Reason being, is because in the stock configuration, the strut is by itself with no load and the spring is in another location. With the spring now being around the strut, you have now put a lot of energy/stress in that spot. I told him I have a UMI strut bar in place. He said, "trust me, you will eventually rip the top half of that perch off on a hard launch if you don't weld gussets in that area, or tie in a rollcage on top of that spot. Just food for thought.
What about adding a couple of bars across
He means like this.
Thanks, I guess I can still do that. It’s not like you be able to see it anyways right. I mean I’ll damage the powder coat but I rather be safe. How thick is the plate?
