Frame mods- weight savings
Louie L.
Habitual Line Stepper
Staff member
In order to repackage my turbo system and loose some weight off the nose of my GN, I have began some serious chassis mods. I have removed the frame rails in front of the motor in order to replace it with a cm loop. I have also removed the radiator,fan, hoses, core support , water pump, turbo oil pump.
To loose weight in other parts of the car, I have gutted the dash, wiring harness, e brake pedal assembly. I have also replaced the stock steering column with a light weight TRZ unit.
I'll be installing the loop in few days.
Maybe, if he ever finishes it! That turbo looks a LOT bigger than the X275 88mm that PTE calls it :cool:
X2 - you ever going to finish that thing Louie? :p
Do any of us ever "finish" a car?
