In order to repackage my turbo system and loose some weight off the nose of my GN, I have began some serious chassis mods. I have removed the frame rails in front of the motor in order to replace it with a cm loop. I have also removed the radiator,fan, hoses, core support , water pump, turbo oil pump.
To loose weight in other parts of the car, I have gutted the dash, wiring harness, e brake pedal assembly. I have also replaced the stock steering column with a light weight TRZ unit.
I'll be installing the loop in few days.
