I think he was wandering about full tubs though rather than mini tub and if doing full tub would loose structure integrity. The only down side to the mini tub is it could still limit how low and how much tire you can fit up inside wheel well due to the curve on the inner tub. Looks good though nice work.. You can still get quite a bit more tire in there with the mini tub and would be alot less work for someone just needing a bit more room. The stance and look I'm going for though would be no way I could get by with doing mini tubs. Another thing for people to consider is Backseats???? mini tub may be the way to go if you would like to keep your backseat. I noticed what you did for trunk hinge clearence..The hinges in these cars sit so low and are bulky..I hate gm's design with them, I think they could have done better but then again who knows...I plan on doing somthing simalar to what you did because my tubs will be little more further in and i plan on getting them to sit little higher..I may just fab up some custom trunk hinges if the factory ones sit too low because I will be useing a 29-30 tall slick
