Very Very good question, Well all of the boxed steel is between 16-18ga which is the thinnist i could buy so its still pretty light but yet still strong due to the fact its boxed..it looks heaveir then it is cuz ofcourse most commomly avalible boxed steel is 1/8inch thick and larger. I have a steel company locally that i special order from directly and i do it under my companys name so im able to by at wholesale prices, i just have to buy in full 24ft pieces or 4x8-4x10 sheets. I did weigh the car on truck scales before mods with everything still stock and with full tank gas w/o driver it was just shy of 3,350lbs..It orginally had 307 engine in the car so that weight was with orginal v8 with the factory,smog and all the extra crap that they put on these cars after 1972..So now ofcourse as you've seen it has the sbc in it now so im pretty its the same weight as the 307 within a few lbs if i had to guess id say the sbc weighs less since it doesnt have all the extra epa crap on the new motor..I will definatly have the car weigh after its complete and let you know..I removed hell of alot of weight with doing the new mods like no front sway bar( since it a drag car) AC/Delete, no smog controls, top end of engine is alum,alum rad, no back seats, fiberglass hood, also changeing to fiberglass decklid, evenually after i paint it will be doing lexan windows..and posb f-glass doors after changeing the glass, the sheet metal going in for the floor is 22ga since there is plenty of floor reinforcment which is a ton lighter then stock floor pans...I've tryed gutting everything out that i dont need..i do have concerns with the addtional floor braces compared to stock but i still need to worry about strength and safety at same time.. but im pretty sure i can get the car at a decent weight when everythings said and done and still keep it strong and stiff..Oh BTW just for kicks and giggles i weighed all the factory wire when i gutted it out and it was almost 35lbs of wire including the computer...lol..I will definatly keep everyone udated with the new weight. I've got couple friends at my local race track(national trails raceway) that have 4 tire scales for their race cars and both said i can use their scales if i need to so i will definatly be able to get you guys a more accurate # cuz i also wanted to use them anyway to find my center of gravity when i bolt the 9 inch rear end under it for good and also so i can get suspension dialed in...Thanks for bringing the issue up because it has been going through my mind durring this whole build...also if incase anyones wandering i had charlie change the title of this thread since i have decided to document the entire build which is the reason this thread reads alittle diffrent as far as the tittle goes
