prostreetdrag
- Jan 3, 2010
Sorry, I guess that may help some people if i posted some measurements. I'm actually working from home so I will go out to garage here in a few and get some quick measurments.... I guess the only reason I didn't think about posting them earleir because my floor pans and driveshaft tunnel will be custom made so someone with a stock floor may have to tweak the measurements for their project since the rear stock floor pans/tunnel sit lower with stock setup.. My floor pans in rear will be level with the front floor pans and my tunnel sits little higher so I can keep everything underneath tucked up higher Also I built my loop based on my ride height...On the bottom section of my loop, I drilled an extra set of mounting holes incase I ever wanted to lower the car I could raise the loop higher to accomendate for diffrent ride heights for more ground clearence
